4th order design 2 alpine type r 15's
4bannger
okay so this is my first 4th order design that I have done. Most of the info that i got for the design was from the SMD forum. Can someone tell me if this design will work and if not what changes do i need to make this deisgn work. Im sure some of the much more experienced box designers can help me on this.
Vehicle : toyota sequoia
Location in the vehicle: behind third row
Space available (Length x Width x Height): 48x 48x 30
Subwoofer make and model: apline type r
Subwoofer Size: 15"
Number of Subwoofers: 2
Type of Port (Kerfed, Slot, Aero, etc.): 4th order slot port
What type of music do you like?: rap
Is your goal SPL or Everyday Music?:SPL
Tuning Freq (Hz): 45 - 50hz
Volume : max
Questions: will the deign I have work
View attachment 26546486View attachment 26546485View attachment 26546484
I'm on my phone and can't read any attachments. What's the sealed volume, ported volume, sealed resonance (Fc), tuning, and port area?
Type R's seem to be well suited for 4th orders.
I couldnt see the sealed and ported volume but it looks like you have a very large ported section and port and smaller sealed section. Usually when you see that, you have a person looking for loud, but just guessing without know specs. Ive had a couple of 4ths but mine were always closer to 1:1 ratios or larger sealed because I wanted low end and more of muscial/flat response and sound.
2:1 ratio and smaller is generally what you want for daily. 3:1 still isn't bad; higher is generally for SPL only..
You have a 4:1 so that's a burp box at this point but may be able to play fine on music, just with more rolloff on the low end... Also there's too much port area. If you're going to adjust, I recommend starting at 1/2 cone area and downsizing until you find a good spot. If you're going for a "one and done" build, I'd do 1/3 cone area as port area.
Figure out your sealed Fc, and if it's acceptable (say mid 40s to low 50s) then tune to that number.
Okay well thanks everone for the info. Im gonna give the 1:1 ration a try. I guess i got some bad information when I was reading up on making them, or maybe did a horrible job at reading it.
anyone have any suggestions with tunning my ported sction.
there is so many variables really. A 1:1 ratio normally work well unless the woofer in question doesnt like seal boxes then I tend to go on the large side for the sealed like 1:1.15
But then you have subs that like sealed boxes. Then you can go larger with the ported side to gain efficiency.
Personally I never go past 2:1 ratios as the pass band is just way too narrow and I never push enough power to need that kind of box.
1/2 to 1/3cone area for port area tends to work well leaning towards the larger port.
passive radiators are not advised for this kind of box they will almost always be damaged.
last few boxes I built were tuned between 46-48hz tuning lower takes alot off the high end and pits it on the bottom end and vise versa
Did you have someone model these subs for you? I wouldnt just pick a ratio to start with because you may end up building a 4th several times to get it to sound right. All the ratios you see are in general and certain subs act differently depending on your goals. I have a 4th design for a Sundown sub that has a smaller ported section than the sealed side. When you look at the graph it is louder from 70 down than it was in the sealed or ported spec boxes but plays pretty flat. That would be a perfect example of somebody modeled it first and played with it real life before telling me what to build. A 4th order can sound good and get loud, or can sound like pooh if something is off.
So it seems like im going to have to try find what works best for me. Ill try a 1:1 ratio. would it be advised that i make the sealed chamber like 1 or 2 cuft bigger than alpine reccomends
Tune the ported chamber to the sealed resonance.
Post the VAS and Fs (and recommended enclosure sizes) and I can give you some numbers to work with, I made a 4th order calculator of sorts for personal use.
You usually don't want to make the sealed size bigger than recommended unless the sub has a high Fs, because you'll drop your Fc really low and have a box with poor response on higher frequencies, and you may end up with a muddy response.
So after doing some research I found a resonance calculator online.
from the apline site
Optimal sealed: 1.75 cuft
Free air resonance (fs): 23hz
Equivalent stiffness (Vas): 100L (3.53 ftcu)
form the Speaker Box Calculations that had the calculator
3db down point (f3): 36.2338 hz
resonant frequency (fc): 33.0752 hz
Enclosure volume (vb): 3.3053 ftcu
Can someone tell me if im on the right track here. From what yous said about tuning the ported to the sealed resonance i should tune my ported section to 33 hz?
4bannger
4bannger
FLA
4bannger
