So make a beauty panel to cover up the rest, and paint the port black.however, mine already has a 11inch diameter hole in it from a stock subwoofer, so I could use a rectangle port going through it, but that would just look weird.
Flare it to the full 11" that the hole in the rear deck is. Just my .02.if its the same port area, and is lots of port area (which it is, a 6inch port for a single 12inch driver) I dont think there will be chuffing...
the other option is to make the round part bigger than 6inches, 8inches maybe, so its no longer an extension of the tuned port //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
With the area I doubt chuffing would be heard.that extended piece of the box going up, changing from that rectangular shape to the tube will cause severe audible turbulence. the tuning may be ok but i cant see how it would sound good regardless
if its 4 1 12 u can draw something up thats alot less complex than that...u wont have to use fiberglass12inch... and why less complex?
edit: hang on! thats not complex anyway!
its just a box, with the bottom extended into the spare tyre well using fibreglass, a divider down the middle somewhere, and an external slot port.
