4th order bandpass, need some assistance
also, any advice about the ports sq"?
is the rule of thumb apply here the ame as conventional ones?
10 sq" per cubic foot?
would it be 70sq"?
or 190sq"?
I would shoot for at least 150 sq. in. (which will be pretty short anyways).
what about more?
would that have a negative effect on anything in this type if application?
I was thinking about leaving the port dead senter, and large enough to have access to the subs behind it
I know it wouldnt be that hard to remove the front panel, swap subs, then attach a new one, but for simplicity sake, Itd be nice If I could arrange it to where eveything was available to be left accessible without damaging the enclosure
It would work, you could make the port something like 20" x 20" to access the subs. The problem is that it starts to get a long. A 20x20 port would be about 15" long if the front chamber was 8 cf. You can bump up the tuning a little bit, lose a little bit of midband output, tuning at 70hz with an 11" x 20" x 20" port, 8 cf front chamber.
okay, gotcha
how close do I need to be to your suggestions you made to achieve a fairly flat response?
I mean, how much leeway do I have, seeing as how its going to be incar, something will pop up Im sure
I just had a moment
Ill just make the port removable, with a large mounting flange, so I can do whatever is called for by the time that comes
dee deee deeeeeeh
thanks again
Yeah, I was actually going to suggest that. I'd probably go for around 200-250 sq. in. still.
Also you could easily experiment with different tuning frequencies that way. Remember that all the specs I've given you are very rough estimates and some fine tuning is still probably needed.
not a problem, it wouldnt be a hobby any other way lol
thanks a lot for the advice
savagebee
sociomagicologistics
savagebee
OK 918
savagebee
