4ogm amp, 2ohm components. question
that's weird -- there's no mention of 2 ohm stereo power, but it IS bridgable to 4 ohms mono - which, impedance wise is the same thing as 2 ohms stereo. At 175w bridged it SHOULD do about 90x2 at 2.
that's what i figured to but to be safe i called Eclipse and they said no. the amp is only a 4 ohm stable amp and putting any 2 ohm load on it will damage the amp. i was wow that's really wierd. and they didn't say nothing.
almost forgot OP if your wanting to stay with Eclipse amps i have an XA2000 i'll sell //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Considering you said you are getting rid of it due to the "lack of power"
Buy and amp that is stable at 2 ohm. There's plenty of them out there.
I have the same problem with my Memphis PR300.2 it is bridgeable into 1 channel at 4 ohms //content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif memphis said that it is not stable bridged to 2 ohms.
I just realized that you said it won't even run stereo into 2, wow, that does ****
//content.invisioncic.com/y282845/emoticons/frown.gif.a3531fa0534503350665a1e957861287.gif its oks i got an xterminator 800.2 coming //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
reed dollaz
reed dollaz
Ocala, FL
helotaxi
Mike Mccabe
