4kw Build in a Nissan Sentra SE-R Spec V
andale927
Well I thought I would start a build log as I have never done one before. My old setup was 1 15 inch Fi BTL on a aq2200d with stock electrical. It wasn't enough. So I have decided to go with the loudest reasonable set-up I can get in my sentra without going crazy and cutting out my rear trunk brace to make a wall. Here is what's going in it:
2x 12inch AA Mayhem's (D1)
AQ3500D.1 Amplifier (4300W RMS @ 1 Ohm @ 14.4V)
Box 4.2 Cubic Feet tuned to 32Hz
Pioneer AVH-P4400BT Touchscreen Head Unit
Polk Audio DB5251 5.25in Component Speaker System
Pioneer 5500T 2 Channel Amp (125W x2 @ 4 Ohms)
270 Amp DC Power Alternator
XS Power D3400 Battery (Starter)
XS Power D3100 Battery (Trunk)
Over 75ft of 0 Gauge (100% Copper)
Well here is what I have done so far, more to come:
Head Unit Install:
Polk Audio Components Install:
Broke 4 hole saws drilling hole for wires for left pillar and only went through 1 for the right... Figures.
Also got the alternator installed today... It was a pain getting to the pulley tensioner on my car. Had to go to my friends garage to use a lift. If only Nissan would have given me about 5mm more clearance...
Can't wait to see what you do with those D1's. //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif Subscribed
Well got the intake installed and holes drilled and XS D3400 installed. Wiring looks messy but it is all soldered and secured. I had to ghetto-rig the positive terminal...
16
737
910
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
790
Currently Audison amps 500.1 and 4.300 with kappa 90csx 6x9 component set. Pair of morel 6.5 rear and a single 10” alpine type R.
856
andale927
andale927
Pittsburgh, PA
Dirtrider4eva
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
