40x Batcap 2000 Look-a-likes
RAM_Designs
SketchUp Master
I will only trade for a solid 2kw at 1ohm(or 4ohms).
Item(s) for Sale: 40x DataSafe batts
http://www.osibatteries.com/p-933-enersys-datasafe-npx-150rfr-sealed-lead-battery-12v-150w-formerly-yuasa.aspx
DataSafe NPX valve regulated lead-acid batteries are designed for high rate discharge applications. These batteries are used primarily where high wattage is required for a short duration. With 50% more wattage available and a 30% reduction in size over conventional batteries, DataSafe NPX batteries offer a superior value.
These DataSafe batts are made by Enersys, who also makes Stinger, Hawker, and Odyssey batteries...which we all know are pretty well respected. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
- Sealed/maintenance-free - no water to add
- Sealed construction - can be operated in any position without leakage
- Rugged construction - high impact ABS plastic cases
- Rechargeable sealed lead acid battery
- Lead-calcium VRLA (AGM) technology
- 34.1lbs
- Dimensions: 7.76"L x 6.50"W x 6.89"H
- Resting at 12.9-13V
- Threaded inserts for easy connections
$105 shipped each
$100 shipped if buying more than one
$80 each for locals
Included in price, will be shipped via FedEx
RAM_Designs
SketchUp Master
RAM_Designs
Rockwall, TX
RAM_Designs
