40hz and below only, high volume sub ..which one?
If you are planning on using a sealed box, you'll probably want to choose a driver that will yield a rather low anechoic F3 (lower than 40Hz) in a moderate sized sealed enclosure. Such designs usually feature a mid to high Qes/Qts and low EBP. They will also have a low SPL/sensitivity rating (per watt of input power) but they make up for that loss in greatly increased low-end sensitivity and extension.
As mentioned, the Alpine Type-X is a good candidate, as is the new ED Av.2.
60ndown
60ndown
ca
Lightninghoof
