4000wtts and lights dim like hell
haaze
FL
Im planning on upgrading to a HO alternator and I was wondering if anyone knew if I could use the Delco type cs144 in a '99 chevy malibu.
I know the 130type is what direct fits it but the 144 is bigger so im not sure if the fitting will be correct.
Im planning on upgrading to a HO alternator and I was wondering if anyone knew if I could use the Delco type cs144 in a '99 chevy malibu.I know the 130type is what direct fits it but the 144 is bigger so im not sure if the fitting will be correct.
Your gonna need alot more than a 144 amp alternator to support 4k. Not to be a dick but really man what kind of electrical did you think you could get away with.
hope you got a capacitor in there somewhere
guys thats mean.
You are going to need an actual HO alt..somewhere around 200 would be alot more helpfull then a 130 or a 144. Also you will need to upgrade your stock battery to a stinger or kenitik ( sp idc ) as well as probably running another battery in the trunk.
what amp are you running, what ohms is your system at?
a few of them for 4k watts
or just one really big capacitor... like say 8 farads or above should do the trick even 6 farads would be plenty but 8 just to be on the safe side although i have seen a 100 farad cap which would be more than enough
haaze
haaze
FL
Mr. Slate
