Note: All hypothetical situations should be taken into thought, with use of proper gain control.......using a 4000w amp, 2 channel......soo 2000w per channel and that would make around 1000RMS per channel??
Hypothetical Situations
A.
(2) 10" 600w max (300rms) subs
It would underpower these subs. Make sure to set the gain to not clip the amp too bad.
B.
(2) Kicker CVR-12 or L5 or L7 12"
C.
(2) 15" Kicker CVR 2000w max (I think they are 1000w rms)
It would greatly underpower these subs. About a fifth of the power needed to run these. Make sure to set the gain to not clip the amp too bad.
(I know, these are major factors..........but OHMs, wiring, etc. are not taken into consider.......just general analysis')
Remember, proper gain controlling.........would it be possible/would that be a plausible setup?
What ill effects do you see happening on each setup?
How likely are those ill effects to happen and how long before they would happen (period of time)?
Please give your thoughts on each setup
