4-way active xover
jmanpc
CA.com Nostalgist.
Well I sold off my old 3-way active crossover because I've had to do some real...afro engineering to get my xover points correct. I'm looking for a 4-way xover because I've got a 4-way setup (sub, midbass, mid, high for you noobs), so not just any active xover will do. I'm not exactly rich, so my choices are very limited.
I've really had my eye on the one found here. I am very aware that the xover has switched points, not dials, so it has a limited amount of adjustment. I am okay with it, as the xover points would work fine, but I'm not thrilled about it.
I might could even use a 3-way xover, and just cross my sub over straight from my headunit, and use the subwoofer channel for midbass if the LPF xover point will go to ~250hz.
Got suggestions? Price range is up to $150 shipped, but I'd prefer to spend less.
I think either of these would work. But someone with more knowledge might be able to help. What about the PPI FRX-456. Seen a couple in different cars never owned one. I have not seen one of these for 150.00 yet. I would like to have one myself to try out.
I think the PPI OMX-432 would also work. I have never personally delt with a OMX-432. I know these can he had for 150.00 or less.
No problem. I have been trying to decide what to do also. I have the ARC MX-3 but I really need a 4-way. Good luck on the OMX-432 they are pretty easy to find.
jmanpc
CA.com Nostalgist.
jmanpc
Jacksonville, Fl
genxx
