4 Subwoofers advice
I've heard the polk mm line wish ok to me.you can take a chance & listen to what guys on this forum are to tell you or you could just waste you money on ok product.
just because you are use to knowing mainstream brand names, doesnt mean that there isnt cheaper for better out there.
read & learn
Thank you okiedokie....your expertise is greatly appreciated !!!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
in a sealed box, i'd go with the polk off that list. 25 mm of xmax. how far off the floor is the sub?
Thank you kcdc30 for the advise.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
The sub will reside in a custom, fiberglass enclosure that encompasses the spare tire. The sub faces down into the spare tire's wheel as the spare tire is 18" in diameter that tapers inward to 14" total diameter. The distance from the front of the sub's gasket mounting surface to the spare wheel center is roughly two inches. If I'm not mistaken 25mm is about an inch ??
The enclosure is already built as this is how the customer wanted it built. It's just the availability of 10" subs are limited to the depth of this enclosure.
That is correct, I have one .7 cubic feet box for one 10" sub and it will be powered by one amp.
There are four subs that I listed that I need your expert advise on, but only need one sub.
Does this mean you will have 4 amps when you power 4 subs, or
still just one amp?
Does this mean you will have 4 amps when you power 4 subs, orstill just one amp?
Sorry for the confusion but it's just one amp, one sub , one fiberglass enclosure.
The only subs I could find with the appropriate depth are the four listed. The brands are "mainstream" as that is all the inventory that I have access too.
I finally see the light!
tubbedz
Junior mint
tubbedz
50th state
mcsoul
michigan born
    May 14, 2026
michigan born
    May 14, 2026
