yeais your amp stable at 2 ohm stereo? if it is, then just wire the two speakers in parallel. on the FL and RL connect the speakers + to + and - to -, and do the same to the right side.
if you already have the wires run, then just connect them behind the dash and run a two singles back to the amps, or if they are run to the amps already, then connect them at the amp. if the wires are already ran, like even if they were connected to the deck, you can still do it there.yea
if i wire them in parrellel then dont i have 2 run it all the way 2 the back 2 the other speaker to do that
My speakers are 4 ohm
2 of them for right now but i want 2 eventually have 4 would i need a new amp
the amp i have has plenty of power 2 power 4 just not enough channels
are the rear speakers already playing, like off the h/u or something?nothing is run yet but im confused about what you just said
wow, i really shafted that last thread. i guess i shouldnt watch the TV and post at the same time. anyway, replace the rears, then behind the deck where they were connected to the deck, connect both the left sides and right sides + to + and - to - like i said before, then run two strands of speaker wire to the amp and connect them, that way you dont have to connect them in the doors or run four wires to the amp.Everyone in this thread needs to go back to middle school and retake english classes.
are you saying run wires from like both speakers on the right then splict them into one for the total right side and put it on one channel of the amp them do the same for the left and put it on the other channel.wow, i really shafted that last thread. i guess i shouldnt watch the TV and post at the same time. anyway, replace the rears, then behind the deck where they were connected to the deck, connect both the left sides and right sides + to + and - to - like i said before, then run two strands of speaker wire to the amp and connect them, that way you dont have to connect them in the doors or run four wires to the amp.
People cant help if they dont understand what theyre reading.thats true i **** at english but were not ****ing talking about that are we
or are you saying run a wire between the pos on both speakerr then between the neg of the 2 speakers then run it 2 the amp.is your amp stable at 2 ohm stereo? if it is, then just wire the two speakers in parallel. on the FL and RL connect the speakers + to + and - to -, and do the same to the right side.
