HoeBag
i have a fairly small trunk and since i drive the car every day i prefer to keep the spare tire. given that, i purchased a helix a6 competition amplifier because of the power, sq, and small footprint. it will be mounted against the 'firewall' in the trunk and i have some space beside it for a subwoofer(s). out of haste, or lack of planning, i purchased 4 helix e200 8" slim subwoofers. each requires roughly .5cu ft in a sealed box. i have enough space to have a .75 or 1cu ft ported box on each side of the amp. so 2 8s would be on either side of the amp. OR i can save a little space and go with a 1cu ft ported box on 1 side of the amp for the 12.
here is my dilemma: should i purchase the 12 and try to sell the 8s? will the 1 12 be louder than the 4 8s? will the 12 sound better? or am i just second guessing myself and i should stick with what i have?
specs of the e200 8" sub:
impedance 2x4ohm
fs - 52.1
rms - 110w, max 165w
qts - .79
xmax - 5.5mm
md - 46.3g
sensitivity - 85db
bl - 5.7
vas - 12.9L
specs of the e300 12" sub:
impedance 2x4ohm
fs - 35hz
rms - 400w, max 600w
qts - .57
xmax - 4.75mm
md - 90.8g
sensitivity - 88db
bl - 7.88
vas - 50.2L
specs of the a6 amp:
at 2 Ohms bridged: 1 x 400/640 W channel C +D (12" dvc sub wired to 2ohm)
at 1 Ohm/13,8 V: 2 x 200/320 W channel C +D (2 8" dvc subs wired to 1ohm per channel)
it seems as though the amp is well suited for either the 4 8s or the 1 12.
any help/guidance is appreciated!
impedance 2x4ohm
fs - 52.1
qts - .79
xmax - 5.5mm
md - 46.3g
sensitivity - 85db
bl - 5.7
vas - 12.9L
impedance 2x4ohm
fs - 35hz
qts - .57
xmax - 4.75mm
md - 90.8g
sensitivity - 88db
bl - 7.88
vas - 50.2L
