? Rlp-12"
Depends how stupid your going to be with the gain knob. They don't need tremendous amounts of power to get loud. 1500-200 watts on a burst is all I'd put on it. Longterm the 1000 watts of power handling is probably pretty close. Going over that for very long and you'll probably smell coil around 1200 continous or so.
They definately don't need a lot of power to get moving. If you can send them 600-800 you'll be sitting pretty. I didn't send mine more than 800 or so when I had my RLp 15 in the car.
How are these subs and can they take more than ratedDIYCable.com : Intro » Home » Exodus Subwoofers »
They're low end monsters. The XBL^2 woofers aren't necessarily made for high output, but lots of smooth throw and good distortion levels. And power needed is dependent upon the application you put it in. You seem hung up on underrated woofers...I'd gladly take a woofer that doesn't need a ton of power to get the most out of it.
There's no reason to assume a sub is better because it can maybe handle more power than it's rated for. It just simply means the manufacturer gave it a conservative power rating.
He also keeps picking woofers that aren't really known for being abuse proof lol. Every driver he has picked is generally a higher end driver that isnt' necessarily designed for the boomer crowd.
Paying retail? I know you made up your mind, but I can guarantee those Xcons are NOT 100 dollars better than the Tempest X, if they are at all. I'm not even sure if Dan did the Xcon's design because if he didn't, not all XBL^2 designs are equal.
How much power can these subs take daily in recommended sized ported enclosure with ideal electrical.
you couldnt merge this one with the exact question for the Shiva?
Anywho.. The Rlp to me is a W7 with stiffer suspension and a better motor.. Never had one, but heard one and it was pretty sick off 1500 rms daily
Wiggens has nothing to do with any SSA product, not to mention the Xcon is an overhung design.
Optimus_Prime
Optimus_Prime
Albuquerque, New Mexico
denim
