4 or 2 Channel
Savackz
GA
What is a good 4 or 2 channel that would power some ES 6.1 components from B2 audio? They are 100watts a piece and I am not going to cut into my doors so I only need that or maybe a little over like 150w per channel. I can add rear stage later on if it really changes the sound output that much or might get more powerful speakers upfront. The dome tweeters don't work so they are pretty much just regular speakers. Must be small footprint. No budget as of now or preferences - but keep it reasonable.
Edited post at the top @trumpet. I might try and get a different set of components. The dome tweeters don't work so. I might be able to find a better set if it'll help increase volume all in all. I am only running 45 watts per speaker right now.
[quote name='zscarlson1']Edited post at the top @trumpet. I might try and get a different set of components. The dome tweeters don't work so. I might be able to find a better set if it'll help increase volume all in all. I am only running 45 watts per speaker right now.[/QUOTE]
So you're saying the B2 components have bad tweeters or do you mean they won't fit? If you're going to replace the whole set I recommend CDT HD-62. At over 93 dB sensitivity they will get quite loud and they sound awesome.
Well, I might try and find some pro audio speakers like some PRVs or american bass full range (as I can get a deal on those) and get an amp that does about 125 per channel. The dome tweeter doesn't work becaues I bought it used. Got the speakers for only 50 bucks so.
Savackz
Savackz
GA
Savackz
