nebstewart07
I have a 4 ohm sub dual voice coil sub kicker l7 and a kicker 500.1 amp. I parralel wire the sub and then directly hooked it up to the amp. i am just making sure that i did this correct hopefully i did.
The manual stated that parralel wiring the sub would make it 2 ohm so i guess it should be correct but just making sure.
I had 2 subs and had them hooked up and one blew. I looked inside the box and the dummies had them series wired which would make it 8 ohms each then bridged and then hooked to the amp. That would have caused it to blow correct?
