4 ohm sub only reading at 3.5 ohm's
quins90lac
ok so today i decided that i would hook up my other 760w pioneer amp i used a set of rca y cables out the back of my deck and to sets of rca's . The 2 rca's weer different from each other one was a little longer and the Y cables i used are kinda old .the subs weer hitting hard for about 2 songs and then barely any movement . their supposed to be 4 ohm subs and now they only read at 3.5 ohms im thinking their fucked . or could the problem be the the Y cables weer not allowing the correct pre out voltage to each amp
Can you post this using proper grammer so i can understand why you think there is a problem? Anyway, subs usually read slightly lower than their rating, i have some 4ohm subs that read 3.6ohms.
type R FTW
found the problem im stupid lol . it was a lose ground .tightened it back down and they work fine now. dam i was hopping they would be blown so ide have an excuse to get new subs dam
quins90lac
quins90lac
peoria IL
quins90lac
