pd8731
Banned
For a budget ground pounder wall in an Escort ZX2. Just for the record, I can make it fit.
I'll disregard that. You're retarded.man grab a decent 2500, you will be much happier.. what you looking to spend?
Nah. Even if the amp did do 3k after imp rise and voltage drop it would still only be 750w per sub. They are rated at 600 continuous. I'm sure 150 extra watts won't asplode them if everything is set right.I have a feeling you are going to have to cut the gain way back considering that amps does over 3000w at 14v
You've bewildered me with all those big, scary words! I am truly sorry and I retract my previous statement. I clearly did not know who I was proverbially "messing" with.im a retared, yet the amp your looking for is cheap junk.. i bet you can't tell me how to measure millivolts(dc)..99% of the people here can't use a true rms meter when measuring an amps output, hell most don't know what/who makes good boards/ electronics...
me=industrial electrican.. ill put money ill school you in any field related to car audio.. pos crunch....
do your self a favor and grab a decent amp, the aq 3500 is a much better amp.. you can grab good 2500(cadence daytona 2500) with a good swiching supply and way better filters etc for not much more..
Thank you. If somebody finds a better amp for the price, please link me. I have never heard of such.lol i a nuclear engeering electricians mate. and can say i haven't seen or heard anything bad about the gp300d's. and have heard they are lil power houses.
you may be an "industrial electrician" but my country trusts me enough to work on some very expensive equipment that is high voltage and is important to running a reactor. it takes much more knowledge than what you have papermaker as you have made obvious.
so chill the eff out. if the guy wants a gp3000d all the more power to him. suggestions for an equally capable or potentially better amp i am sure are welcome.
Exactly. Paper factory needs to heed this.lol. no reason to talk down to anyone.
You stole my opinion! //content.invisioncic.com/y282845/emoticons/furious.gif.fc81ca146dbff91fede3ed290dbc4f4c.gifcadence daytona 2500 is a pos
Anything located in my nether regions contains no intelligence, trust me.bunch of smarty pants in here
its the truth true powerhouse here has numbers to prove itOk guys, here it is. Depending on your battery set up this amp will make an ungodly amount of power. With a 12volt battery set up dropping to 11.5 volts the Crunch GP3000D Pro made 2850 watts at a 1.03 ohm reactive. That's 4 12volt batteries. If you can get the voltage up the amp will make much more. By just starting the car and using the high amp alternator (starting at 16.1 volts and dropping to 12.3volts), the 3000 made 3732 watts. That's crazy isn't it. THAT'S NOTHING! I hooked it up to a 16volt battery set up and it just went crazy! With the battery voltage dropping to 15.7 volts with a 1.4 ohm reactive this monster made 4640 usable watts. NOW WHAT DO YOU THINK ABOUT THAT!http://audioforum.termpro.com/topic/20/13407/2.html
junk huh?
