4 channel + mono amplifier.
[quote name='showpump'][quote name='kramer_212']oh sorry thought you had one, ill look.
check out vertexaudio.com they will work a good deal out for you, when i got mine i just emailed and asked them whats the best they could do for me and they gave me a killer deal. doesnt hurt to ask. the guy i talked to email was cody[USER=612133]@VertexAudio[/USER].co
hope this helps![/QUOTE]
malware.
I will have a Soundstream Reference 2.640 . would make an excellent highs or sub amp.
specs off net. PM me if interested.
RUBI TM (Rapid-Use Branched Impulse) Proprietary Power Supply Topology
• STACT TM (Stabllized Apex Current Topology) Reduces Power Supply Stress b y 50%
• Trident TMAmplifier Protection Topology
• Ultra Low ESR Capacitance Bank Ensures Rapid Power Delivery for Dynamic Peaks
• Hawkins Bass Control TM Proprietary Bass Equalization
• Regulated MOSFET Power Suuply
• Triple Darlington Output Circuitry
• BIP TM Bias Input Protection
• Rail Stabilization Protection Circuitry
• Bi-Linear Variable High, Low, & Band Pass Crossovers
• Balanced Line Inputs for Highest Noise Rejection (requires BLT)
• Tri-Mode Operation
• Multi-Channel Input Selection (4 & 5 ch. models)
• 4ga. Power & 8ga Direct Wire Terminals
• = 0.02%Total Harmonic Distortion
• >110dB Signal-to-Noise Ratio
• >1000 Damping Factor
• 200mV-9V Input Voltage
• 30-80Hz Hawkins Bass Boost
• 180 o Phase Control
* Power output:
o 190 Watts RMS x 2 @ 4 ohms
o 320 Watts RMS x 2 @ 2 ohms
o 640 Watts RMs x 1 Bridged @ 4 ohms
* Regulated MOSFET power supply
* RUBI (Rapid-use branched impulse) proprietary power supply technology
* STACT (stabilized apex current technology) reduces power supply stress by 50%
* Trident amplifier power technology
* Auto high-current, regulates power supply load for application
* Triple darlington output circuitry
* Hawkins bass control: proprietary bass equalization
* Drive delay II eliminates turn-on & turn-off pops
* Ultra-low ESR capacitors for rapid power delivery & dynamic transient peaks
* Tri-mode operation
* Damping Factor: >1000
* Signal-to-noise ratio: >110dB
* 180 degree phase control
* 30-80hz hawkins bass boost
* 200mV-9V input voltage
* 4ga. Power & 8ga direct wire terminal
* Dimensions: H: 2.25" x W: 9.875" x L: 14.875"
REF 2-640 2640 REF-2.640 REF2.640 - Soundstream 370W RMS 2-Channel Class A/B Reference Series Power Amplifier
Related Accessories
ill consider it if it was my car id probably get it read up on it. resembles audison quite a bit though.
Audison and Hertz are both made by Electtromedia. Audison is their "high end" although all their products are high end. I am a dealer of both, so let me know.
I dont recall the series of Hertz but one of the small amps is same board as the polk and the PPI phantom..pretty sure it was Hertz although the Hertz seems to put out more power than any of its counterparts.
ill sell you a Mb Quart Discus 1500.1 and a MMATS SQ4150 for 500 shipped for both.
mb quart dsc 1.1500d specs...◦4 ohms: 375 watts x 1 chan. ◦2 ohms: 750 watts x 1 chan. ◦1 ohm: 1500 watts x 1 chan.
mmats sq4150 specs... 150 x 4 @ 4 ohms 165 x 4 @ 2 ohms 340 x 2 bridged @ 4 ohms
kramer_212
kramer_212
Minnesota
jimmerj18
