4 channel into 3?
There is no reason you couldn't bridge two of the channels (as 94Mazda626 said), as long as it is bridgable. If it is, this will be noted on the speaker connection terninals of the amp. You also want to make sure that the amp is stable to whatever impedence the sub will be at, once it is bridged.
103
351
10
732
Slapz are sfb clones from my understanding. What I was pointing out is how much info slapz gives about their amps 😂
35
Thanks for that. Good point about the chimes, I 'll have to check. My thoughts were that a true center channel could serve to raise the sound...
431
TaylorFade
I fail.
TaylorFade
Baton Rouge, La.
Slammer
    May 31, 2024
    May 24, 2024
