Sold 4 channel and mono AMP
DeViOuSoNe
What's a Subwoofer?
First off is a Pretty new 4/3 channels Sony XPlod Amp.....Not much to say about it really..Its silver and red.. Here are the specs Missing Screws for speakers...Will look for them Or go buy some.
Maximum outputs: Four speakers - 120 W x 4 (at 4 ohms)
Maximum outputs: Four speakers - 150 W x 4 (at 2 ohms)
Maximum outputs: Three speakers - 120 W x 2 + 300 W x 1 at 4 ohms
Rated outputs (at 14.4V): 60 W x 4 (20 - 20kHz, 0.08% THD, at 4 ohms)
Rated outputs (at 14.4V): 75 W x 4 (20 - 20 kHz, 0.1% THD, at 2 ohms)
Rated outputs (at 14.4V): 60 W x 2 + 150 W x 1 (20 - 20 kHz, 0.1% THD, at 4 ohms)
Frequency Response: 5 Hz - 50 kHz (���±3dB)
Harmonic distortion: 0.005% or less (at 1 kHz, 4 ohms)
Input level adjustment range: 0.3 - 6V (RCA pin jacks), 1.2 - 12V (High level)
Low-pass filter: 50 - 300 Hz, -12 dB/oct
High-pass filter: 50 - 300 Hz, -12 dB/oct
Low boost: 0 - 10 dB (40 Hz)
Inputs: RCA pin jacks, High level input connector
Outputs: Speaker terminals
Speaker Impedance: 2 - 8 ohms (stereo)
Speaker Impedance: 4 - 8 ohms (when used as a bridging amplifier)
Power requirements: 12 V DC car battery (negative ground)
Power supply voltage: 10.5 - 16 V
Current drain: 31 A (at 4 ohms, rated output)
Supplied Accessories:
Next is a 800 watt mono.. It is the Octagon one...Also Silver and red...Cant find specs on it though. In Great shape
100 shipped for both OR BEST OFFER //content.invisioncic.com/y282845/emoticons/up2something.gif.dd110ecf3ae4b76050d87598f2f8de7c.gif
DeViOuSoNe
What's a Subwoofer?
DeViOuSoNe
MD
BLD 25
