4 channel amp wanted
well, i have one, but it isnt that big. its a zapco 360.4 reference. if you wanted to run the subs as well, i have a 500.1 reference, you can bridge the 360 and use the 500 for the sub.
^real power, i guess that was necessary.
American Bass SQ-480
NEW!!! This amp is VERY under rated. I would say it puts out almost double what is advertised. I have seen this amp push 2 competition 12's extremely Hard. I know for a fact that this amp is way more powerful than these numbers.
RMS AT 2 Ohm Stereo 80Wx4CH
RMS at 4 Ohm Stereo 60WX4CH
RMS at 4 Ohm Mono 130WX2CH
MAX at 2 Ohm Stereo 150WX4CH
S/N Ratio > 100db
Channel Seperation > 55db
Input Sensitivity 0.15V - 5V
Input Impedance 47K Ohm
Slew Rate 10V /Usec
Damping Factor 200 at 4 Ohm
Fuse Rating 25A x 2
Width 9.54"
Height 2.13"
Length 13.78"
$180 Shipped
S/N Ratio > 100db
Slew Rate 10V /Usec
Fuse Rating 25A x 2
Width 9.54"
Height 2.13"
Length 13.78"
$180 Shipped
And what is this magical amp called?
Ooops I copied this out of my outbox in PM's The name of the amp was in the title. It is a American Bass SQ-480 and it is Verry powerful for a 4 channel. My brother runs 2 American Bass Cast 12's off of 2 of the channels. The other 2 channels go to a pair of 25mm Cast Dome Titanium Tweeters. The amp is set at 80% on the subz and 30% on the Tweets. It worked out perfect for him becasue it has the build in crossover to separate the front and rear channels.
Give me prices? I am trying to get a amp under 180 + shipping. I need it to run my whole system at the moment. I have a 15" oz audio power series . the 700/1400 watt one and bose speakers.
ent3rdadragon
ent3rdadragon
San Diego, CA
guy022077
