4 Channel amp or Mono needed.
ekah
Just curious on a step up from what I have now.
Running a cab 1600 and a ppi900.4
Psi platform 2
Jbl p660c front.
Need ideas on anything a step up from these items other than my sub I wanna change the fronts and 4 Channel and Mono amp. I wanna be a bit louder. Idk if me having a stock 110 alt is a big problem or it's the amp or speakers that I need to upgrade to be a bit louder
Sent from my SM-G935T using Tapatalk
You got good equipment. Not sure what you mean by upgrade to be louder.
Well to be louder will cost $$. You could get 4 12's run them off that same amp and be 2x louder. Just for example.
Sound deaden doors and seal off any large holes.
Build a better sub box.Too large or small? Tuned too high or low? Not enough port area? Change sub and/or port location. Change actual location of box in vehicle.
I could run 4 subs on my 1 cab or multiple cabs? I should build a better box though psi sent me some diagrams for 34 Hz box. Changing port location makes a different? If deaden doors and I have a hatch maybe I can deaden the tire well where the sub sits?
ekah
ekah
hawaii
wew lad
