4 chan amp
hockey512546
i'm trying to figure out what i'm going to do as far as an amp
was wondering if it is possible to bridge 2 channels on a four channel for a sub and then use the remaining 2 channels to power components
or would I be better off just getting a 2 chan amp for the comps and a mono for the sub
no idea how much power i want for either, just trying to get an idea
it would depend on what your wanting run off of the amp or amps. a lower power sub stage would be fine with a 4ch. if your wanting to run better subs then i would go with the 2ch and mono or a 5ch.
75 rms on the comps and maybe 500 on the subprobably good to use a 2 chan and a mono then right?
Bloomington IL
Or you can go with a 5ch such as the Mobile Spec ICEX-5400
Class AB Section*
50 Watts x 4 @ 4 Ohms
75 Watts x 4 @ 2 Ohms
150 Watts x 2 @ 2 Ohms Bridged
Class D Subwoofer Section*
200 Watts x 1 @ 4 Ohms
300 Watts x 1 @ 2 Ohms
400 Watts x 1 @ 1 Ohm
*All wattage is RMS.
hockey512546
hockey512546
Bloomington, IL
n2audio
