4-b2 audio m1
nutnbutcustm
IM OLD
Item(s) for Sale: 4-B2 AUDIO M1
Frequency Response: 15 Hz ~ 250 Hz
Signal to Noise Ratio: 100 dB
Input Sensitivity: 6 ~ 0.2 V
Crossover: 24 dB/Oct
Low Pass Filter: 35Hz ~ 250Hz
Subsonic Filter: 10Hz ~ 50Hz
Bass Boost: 0 ~ 9 dB
Phase: 0 ~ 180°
Damping Factor: 300
Power Terminal gauge: 0 GA x 2
Fuse Rating: 750 A
Operational voltage: 9 ~ 18V
14.4V 16V 18V
Power @ 4 Ohm: 1 x 2600 w / 1 x 3300 w / 1 x 4000 w
Power @ 2 Ohm: 1 x 4800 w / 1 x 5800 w / 1 x 6900 w
Power @ 1 Ohm: 1 x 8500 w / 1 x 9100 w / 1 x 9500 w*
Power @ 4 Ohm: 1 x 9600 w / 1 x 11600 w / 1 x 13800 w linked
Power @ 2 Ohm: 1 x 17000 w / 1 x 18200 w / 1 x 19000 w linked
THESE HAVE BEEN CLAMPED AT 14K PLUS EACH SO YOU DO THE MATH.
Item(s) Description/Condition: 3 OF THE AMPS ARE 9.9/10 JUST BECAUSE THEY HAVE BEEN HOOKED UP THE 4TH ONE IS A 9/10 BECAUSE OF A SMALL SCUFF ON THE MOUNTING PAD, ALL 4 WORK FLAWLESSLY.
Price: $1850.00 EACH SHIPPED AND INSURED CONUS, THE MORE YOU BUY THE CHEAPER THEY ARE.
Shipping and Miscellaneous Item Information: ON MY DIME ONLY TRADES WOULD BE FOR SOME VERY HIGH END SQ AMPS OR NEW PIONEER SQ DECK
nutnbutcustm
IM OLD
nutnbutcustm
Spring,TX.
nutnbutcustm
