4-b2 audio m1
nutnbutcustm
IM OLD
Item(s) for Sale: 4-B2 AUDIO M1
Frequency Response: 15 Hz ~ 250 Hz
Signal to Noise Ratio: 100 dB
Input Sensitivity: 6 ~ 0.2 V
Crossover: 24 dB/Oct
Low Pass Filter: 35Hz ~ 250Hz
Subsonic Filter: 10Hz ~ 50Hz
Bass Boost: 0 ~ 9 dB
Phase: 0 ~ 180°
Damping Factor: 300
Power Terminal gauge: 0 GA x 2
Fuse Rating: 750 A
Operational voltage: 9 ~ 18V
14.4V 16V 18V
Power @ 4 Ohm: 1 x 2600 w / 1 x 3300 w / 1 x 4000 w
Power @ 2 Ohm: 1 x 4800 w / 1 x 5800 w / 1 x 6900 w
Power @ 1 Ohm: 1 x 8500 w / 1 x 9100 w / 1 x 9500 w*
Power @ 4 Ohm: 1 x 9600 w / 1 x 11600 w / 1 x 13800 w linked
Power @ 2 Ohm: 1 x 17000 w / 1 x 18200 w / 1 x 19000 w linked
THESE HAVE BEEN CLAMPED AT 14K PLUS EACH SO YOU DO THE MATH.
Item(s) Description/Condition: 3 OF THE AMPS ARE 9.9/10 JUST BECAUSE THEY HAVE BEEN HOOKED UP THE 4TH ONE IS A 9/10 BECAUSE OF A SMALL SCUFF ON THE MOUNTING PAD, ALL 4 WORK FLAWLESSLY.
Price: $1850.00 EACH SHIPPED AND INSURED CONUS, THE MORE YOU BUY THE CHEAPER THEY ARE.
Shipping and Miscellaneous Item Information: ON MY DIME ONLY TRADES WOULD BE FOR SOME VERY HIGH END SQ AMPS OR NEW PIONEER SQ DECK
yep, ive seen him with the quota and zero, but im assuming the 9k is nothing like the smaller ones.
I would assume they would rate their amps similarly across the board, but I could be wrong.
Don't know much of B2, do they like .5ohms?
.5 shouldn't be an issue daily, believe they can handle even lower for burps.
it may be more convincing if you can provide a true clamp test. Saying you get 14k ea out of a 9k amp is a little rich to say. If they honestly do those numbers, thats amazing, but i cant see it.
you dont have to see it, the video where they were tested is on b2's website i believe or their fb page, i am the one that tested them with the video to prove it. These amps are used by several world record holders, just like the b2 m1s is rated as a 7k but clamp at over 9k all day long.
... what does 160 feel like???... im so curious...
---------- Post added at 09:20 PM ---------- Previous post was at 09:19 PM ----------
oh **** ur in spring tx... dude im in 77379.... around the klein area... can I get a demo.... I will happily pay you for the gas wasted for your car to be on and some wataburger
Managed to get a video of a demo he gave me. I'll post the link tomorrow
nutnbutcustm
IM OLD
nutnbutcustm
Spring,TX.
nutnbutcustm
