4-b2 audio m1
nutnbutcustm
IM OLD
Item(s) for Sale: 4-B2 AUDIO M1
Frequency Response: 15 Hz ~ 250 Hz
Signal to Noise Ratio: 100 dB
Input Sensitivity: 6 ~ 0.2 V
Crossover: 24 dB/Oct
Low Pass Filter: 35Hz ~ 250Hz
Subsonic Filter: 10Hz ~ 50Hz
Bass Boost: 0 ~ 9 dB
Phase: 0 ~ 180°
Damping Factor: 300
Power Terminal gauge: 0 GA x 2
Fuse Rating: 750 A
Operational voltage: 9 ~ 18V
14.4V 16V 18V
Power @ 4 Ohm: 1 x 2600 w / 1 x 3300 w / 1 x 4000 w
Power @ 2 Ohm: 1 x 4800 w / 1 x 5800 w / 1 x 6900 w
Power @ 1 Ohm: 1 x 8500 w / 1 x 9100 w / 1 x 9500 w*
Power @ 4 Ohm: 1 x 9600 w / 1 x 11600 w / 1 x 13800 w linked
Power @ 2 Ohm: 1 x 17000 w / 1 x 18200 w / 1 x 19000 w linked
THESE HAVE BEEN CLAMPED AT 14K PLUS EACH SO YOU DO THE MATH.
Item(s) Description/Condition: 3 OF THE AMPS ARE 9.9/10 JUST BECAUSE THEY HAVE BEEN HOOKED UP THE 4TH ONE IS A 9/10 BECAUSE OF A SMALL SCUFF ON THE MOUNTING PAD, ALL 4 WORK FLAWLESSLY.
Price: $1850.00 EACH SHIPPED AND INSURED CONUS, THE MORE YOU BUY THE CHEAPER THEY ARE.
Shipping and Miscellaneous Item Information: ON MY DIME ONLY TRADES WOULD BE FOR SOME VERY HIGH END SQ AMPS OR NEW PIONEER SQ DECK
still have one left, im somewhat negotiable on the price, but keep in mind i see others on here selling the little brother m1s for about the same amount im asking for this.
what do you mean little brother M1s? Whats the difference between your M1 and others?
You have me thinking about selling my RD. But it depends on how flexible you are...
what do you mean little brother m1s? Whats the difference between your m1 and others?
You have me thinking about selling my rd. But it depends on how flexible you are...
bottom line i will do $1650.00 cash after fees and you cover shipping. And here are the differences..... :)
m1s 12v 14v
4ohm 1800 2400
2ohm 3200 4200
1ohm 5500 6500
strapped @ 2ohms 14v 14,200 watts
m1 mkii 12v 14v 16v
4ohm 2000 2800 3300
2ohm 3700 5300 6300
1ohm 6500 9900 11,500
strapped @ 2ohms 14v 19,000
strapped @ 2ohms 16v 24,500
these amps are both very under rated. The m1 has been clamped @ .35 @ 13.1 v = 14k watts
m1s 12v 14v
4ohm 1800 2400
2ohm 3200 4200
1ohm 5500 6500
m1 mkii 12v 14v 16v
4ohm 2000 2800 3300
2ohm 3700 5300 6300
so yours is the m1 mkii?
nutnbutcustm
IM OLD
nutnbutcustm
Spring,TX.
nutnbutcustm
