4 apline type r's
ive been using the drafting program from google and ive been using different box calculators to come up with some way to make the boxes fit and to where they have the right frequency and sound right
Don't waste your time man.
With the dimensions you listed, thats a MAXIMUM of 5 cubes. That doesn't include any sub or port displacement. For a ported application, you're looking at a minimum of ~1.25 cubes per sub AFTER displacement. That's already 5 cubes right there. Factor in port and sub displacement and you're looking at more like 6-6.5 cubes MINIMUM.
You just don't have the space to fit 4 10's ported.
u r looking at 4.9 before any sub and port displacement with the dimensions you gave
heres the maunfactures specs
Sealed Box Volume: 0.5 - .8 cubic ft
Ported Box Volume: 0.6 - 1.25 cubic ft
you are looking at 1.2 cu ft per sub before any displacement at all so no way ported unless you have a supersmall aero port box but i would just go with 4 of them sealed or 2 ported and put alot of power to them
only way to go ported is give each sub 1cu ft net and do aeroport so you will have right around 1cu ft for aero and sub displacement which can easily be done
use a 6" aero and tune the box to 34hz will give you 28" of port area and the aero displacement will be .18 then i am not sure but guessing each sub is around .06-.08 for displacement just say .08 thats .32 also
so .32+.18=.50 displacement so that would work and leave around 4.4-4.5 which will give each sub about 1.1net so thats about the only way but i would go 2 ported or 3 tops or 4 sealed
one 6" aero isn't sufficient port area for 4 10's. 2 is the minimum I would do.
I wouldn't put type-rs in 1 cube ported either. 1.25 is about as small as I would go.
I just finished putting (ONE) 10" type-R in the LOML's jetta in a sealed box. Believe me...you won't need 4 for others to hear you coming. Save the frustration and build for 2 ported 10 inchers.
The single 10" really pounds hard, anymore and I will need some loctite //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
You could sell the other two or save them for another project.
hittin_hard
hittin_hard
martinsville, IN
82 cutlass
