4 15inch subs vs 1 18
Im looking to buy some new subs for my explorer.
Should I run 4 15 inch soundqubed hds300s or 1 18inch hdc4
what would be the loudest
the 4 15s is only 200 more or would 2 of those 15s be louder then the 18
the 4 15s should be EASILY LOUDER there is way more cone are between them. 4-15s = 706.84 vs 1-18=254.47......
1 18 would be pretty much like having 2 12s in terms of loudness. 4 15s would be like 3 18s pretty much although 3 18s have a LITTLE more cone area but still pretty similar.
Google subwoofer cone area chart and if you ever need to know what would be louder, refer to the chart. more cone area means more air that will be moved (typically), and sound is basically squiggly air so more air = more loud. You should also look at the xmax of whatever subs you're comparing but typically cone area should be the determining factor in what will be louder. Now, regarding exactly how MUCH louder 4 15s would be compared to 1 18, idk how to calculate that. 4 15s have triple the cone area of 1 18 though so you should expect it to be a lot louder lol.
You also need to consider if you are giving the subs the power they need, and if your box is made for the subs.
Are you taking out rear seats as 4 15's will need a VERY big enclosure to get the most out of them?
Otherwise a single HDC4 18 on enough power/proper box will do a 50+ in a Sploder...
not taking the back seats out but if I do 4 15s im going to do a wall and if I do the 18 just a nice custom box in back
That's a HUGE diff in enclsoures lol
Personally I'd do the wall as that will be much louder.
Just walled my son's CRV for 4 15" HDC4's. He lives in Indy and hits up some of the local hangouts...
southport2014
southport2014
Indianapolis, IN
mlstrass
Mike Mccabe
