4,000+ amps for Daily Driver ???????
teedot231999
Mr. Beat's
I am in search of a quality amp that can power a DD Z sub. I am not sure what
size I will recone these subs to but for argument sake lets say two 18's. I know
Alan Dante broke the world record with these subs powered by I believe four 7kd
Stemson amps. Cutos to him for putting up 180+ db's:clap://content.invisioncic.com/y282845/emoticons/applause.gif.bb805d8088f72dbc2fe808c29e85fb4c.gif//content.invisioncic.com/y282845/emoticons/celebrate.gif.82eef51c49c9919296cb60fd0d148863.gif//content.invisioncic.com/y282845/emoticons/goldcup.gif.fed6f294523aaacf5ee40f0193e776f8.gif. Well as for me I'm not
out to set any world records if I do then so be it but this setup is a daily ground
pounder not a dedicated Spl car. I might do a couple local bass race comp as
well as some street bass comp but thats about as far as I plan to go. A lot of
people say 20,000 watts for a daily driver is insane,stupid and a waste of money
Then in the same breath they hang all over Steve meades nuts. I wanted the
opinions of some big dawgs like Louisiana CRX, RyanM923,Sean Dub,Team H&K
StreetdreamsCC as well as any other members who has used or currently using
amps pushing 4,000' watts or more. I don't want to go real cheap (I mean the
amps quality not price)because that would be an injustice to these killer subs. I
am not sure if I should do dual 2ohms or dual 1ohm subs. My question to you all
is what amp or amps would push out sufficent power to these subs and not
get super hott and also staying with in my budget of $2,500 maybe a smigen
more? Thanks for any good advice and positive comments.
Here are a list of amps I like
Two of these
Digital Designs Z1a
Two of these either to 1 sub or 1 on each sub
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18160
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18564o
One of these
http://www.audio-warehouse.com/web/mdl/XXX-10000D/detail.asp
One of these per sub
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18565
One of these
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=18566
Two of these
http://www.audio-warehouse.com/web/mdl/HK4000D/detail.asp
A little too steap for me but nice
http://www.onlinecarstereo.com/CarAudio/ProductDetail.aspx?ProductID=16720
Two of these
http://www.woofersetc.com/index.cfm?fuseaction=product.display&Product_ID=3707
I am by no means a big dog in the car audio game, but I do run a lot of watts daily.
Anyway, if you have $2500 to spend on amps, I would buy 6 AudioQue 2200s and strap those bishes. 13,000+ watts for under $2500 new is a hell of a deal.
i would keep it simple... don't go beyond 2 amps. when you get into 4, 8, etc ammount of amps its such a pain to keep everyhting matched.
with that kind of budget you could get a pair of z1a's used... which i would definately do.
I havent ever ran any where near that amount of power..but you could get 4 Audioque 3500d's for ~$2700 shipped to your door. That's 14000+ watts or 20,000+ with 18volts. //content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gif No matter how you justify it, that's alot of power for a daily driver. //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif From the amps you're posting it looks like you dont want to run that much power, so 4 AQ2200d's would give you ~ 9000 watts for ~$1500. Basically with a little more than $2500 budget, you can have 15000watts, but do you NEED 15000 watts? //content.invisioncic.com/y282845/emoticons/laugh.gif.48439b2acf2cfca21620f01e7f77d1e4.gif
I am using an XXV Maxximus for daily and it is freakin sweet. It delivers the power for hours.
The soundstream is not good for daily, it is meant for 16v systems since it draws alot of power.
The MA also draws alot so I dont recommend that for daily.
If you use DD get this years 12v versions as the regular DDz1A is really meant for 16v but does do good on 12v, the 12v is just more efiecient on a daily system.
The Sampson is a good amp but really likes 16v systems. I would stick with Goliaths or a Maxximus.
40.1 if you can find some... If not got with some RD Audio 7250.1's or maybe some DD z1a
I thought about This amp also. i saw one 4sale in the classified on this forum but it doesn't work:( but It would be a good investment for only $400.
teedot231999
Mr. Beat's
teedot231999
corona,NY
PSturmer
