3Sixty.2 Active system question.
jgonino
I want to run my whole car active, and I need a little help understanding this. I am using the RE XXX components in front, and a FI Q sub in the trunk.
I am guessing I would run the tweeters and mids on a separate channel each. Front output on the 360 for the mids, and use the rear outputs for the tweeters.
I would run all 4 channels to my alpine PDX4.150. For the sub, how do i use the single RCA output of the 360 to send the sound to the Mono sub amp? it has left and right input. Do i just split it?
Most of the time, you can just plug in a mono RCA to either the left or the right.
im thinking your gonna need 2 sets of rcas
your going to need high left and right
and mid/full left and right
what are the outputs labeled on the 3sixty?
that would help out to
it has 6 channel input, and output.
I am running this with my cars stock HU, so I will be using the high level inputs.
I/O is front LR, rear LR, Center, and sub.
well thats not active unless the 3sixty has a way to make the front or rear outputs
high or mid
i think it would be easier to just get a headunit that has active control
you can basically send any freq range to any channel. IE:
Sub gets 20-70HZ, mids get 70-2300hz, tweets get 2300-20kHZ
QFT. I think you can set each channel independently on the 360.2 as well as eq each channel independently.
from Fosgate
6-channel high-level input
6-channel RCA level inputs (FR/FL/RR/RL/Center/Sub)
Independent 31-band EQ for Front Left and Front Right
Independent 27-band EQ for Rear Left and Rear Right
27-band EQ for Center
10-band subwoofer equalizer
6-channel HP/LP/BP/AP adjustable crossover
Up to 5 feet of delay per channel in 2 inch increments (subwoofer excluded)
Auxiliary RCA input with 31-band adjustable eq
Auto equalization with auto sum capability
Digital Signal Processor with OEM integration capabilities (patent pending)
Remote programmable master volume/aux volume control
Wireless Bluetooth™
From the manual
The crossovers for each channel can be configured as either high-pass
(HP), low-pass (LP), band-pass (BP) or completely by-passed (AP).
Except the subwoofer channel which is set to low-pass (LP).
jgonino
jgonino
Kansas City, MO
jgonino
BP1Fanatic
BP1Fanatic
