PLEASE ONLY POST IF YOUR WANTING TO BUY.
3 RD Heavyweight 15s dual 1ohm. The only resaon I am selling is because I need dual .5ohms. Only trade will be for either 3 RD Heavyweights dual .5ohms, or 3 Atomic APX 15s dual .5ohms or dual .35ohms. I HAVE SEEN THE MOTORS ALONE SELL FOR MORE THAN THIS.
3000-4000 watts RMS
25mm tall top plate
25mm tall t-yoke
Paper cone highly damped with Kevlar fibers
Tri layer wide roll surround foam
Dual stacked 1” tall by 9.25” in diameter magnets
Tall titanium former
3” extreme temp 8 layer voice coil
Resign impregnated poly cotton spiders
Cast basket
Spiders bolted down to cast basket
Triple joint re enforced
15″
FS: 44.7 HZ
RE: 3.6 OHM
QMS: 9.6
QES: 0.412
QTS: 0.395
RMS: 11.05
CMS: 0.0334 MM/N
MMS: 378.26 G
BL: 32.14 TM
SPL@1W: 91.83 DB
VAS: 37.83 L
XMAX: 15 MM
XCOIL: 55 MM
Oh coarse one got the screw hole threw the surround, but black silicone took care of that. Doesn't affect the performance at all. Still stiff and still working 100%. One of them, the push terminal broke free from the other one, and I used epoxy to put it back. It does not affect the performance at all. I still manage a 158dbs with one pf600 amp.
$350ea shipped. I only want to sell all three, so if you want one, then we will have to wait for the other 2 to sell and vice versa, or $1000 for all 3 shipped. If your local and come pick them up, I'll throw in a mojo motor, it is from the 2009-2010 Mojo15Q1 sub (all it needs is a bolt on recone).
included in price.
3000-4000 watts RMS
25mm tall top plate
25mm tall t-yoke
Cast basket
15″
FS: 44.7 HZ
RE: 3.6 OHM
QMS: 9.6
QES: 0.412
QTS: 0.395
RMS: 11.05
CMS: 0.0334 MM/N
MMS: 378.26 G
BL: 32.14 TM
SPL@1W: 91.83 DB
VAS: 37.83 L
XMAX: 15 MM
XCOIL: 55 MM
included in price.
