3000 wRMS within 1G
To beat the competition, you have to think "Big", but most of all you have to go "Nuclear". Soundstream engineers designed the XXX-6500D amplifier to produce 6,500 bone-crushing watts in one heatsink. If 6,500 watts aren't enough, strap 2 of the XXX-6500D together on a 2-ohom load and blow away the competition with 13,000 watts of mind melting power.We have been working on this Top Secret project for the past 2 1/2 years to bring you the most advanced and powerful class "D" amplifier in the world. Can you handle the power?
Feature XXX-5000D
OUTPUT POWER: RMS/Chan @ 4 Ohms (Watts) 3400
RMS/Chan @ 2 Ohms (Watts) 4800
RMS Bridged @ 4 Ohms (Watts) 6500
T.H.D:. 1.0%
DAMPING FACTOR: >350
FREQUENCY RESPONSE(Hz): 5-250
INPUT SENSITIVITY: 0.5-10 Volts
CONTINUOUSLY VARIABLE ELECTRONIC CROSSOVERS: LOW-PASS SLOPE 24dB
S/N RATIO: >80dB
LOW-PASS FREQUENCY (HZ): 40-160
SUBSONIC FILTER SLOPE: 18dB
SUBWOOFER EQ @ 45Hz: 0-18dB
wooh thats alot of info //content.invisioncic.com/y282845/emoticons/yumyum.gif.0556df42231b304b9c995aefd13928a8.gif Price?//content.invisioncic.com/y282845/emoticons/greedy.gif.5a53e6246569d7ab79867170f3b06629.gif
i hope that post was a joke.
what you just said was "playing square waves is worse than overpowering a sub"
how does that not make sense, a square wave is worse on an amp/sub than a reg wave, plain and simple:)//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
oh sht dude... underpowering a sub vs. overpowering is all using sine waves. Comparing low signal with clipping to high signal without is retarded. Of course it'll break stuff. But a low signal with clipping vs. a high signal with clipping, the high wattage will blow it a lot faster than the low wattage will. Don't turn things around to try to prove a flawed point.
im not trying to prove a flawed poin like i said MOST people turn the gains up more to compensate for the lack of power. hell if your over powering a sub with a clipped signal then yeah its gunna blow faster than a clipped signal of lower power, but how many people will turn the gain up with more power than needed? not many due to the fact that they know its enough power and they dont have to compensate for anything.
Ok I have 2 things to say on this thread. 1) The soundstream amps are no joke, I have 10 of them. The do awsome power at .7 and 18v's!
2) Not enough power will definately hurt a woofer than too much power. You can always turn the gains down on too much power, but cant do anything with not enough power. I clipped singal is WAY worse for a coil, than the thermal limits of the coil for too much power! Square waves are the worse thing you can do to a sub.
Perfect example. I use 2 RE MT 18's with 8 Soundstream xxx-6500d's. What is the sub rated at 10,000 watts or so. Where I am sending almost 30,000 to each one, but the signal is clean, so the subs are doing great.
I almost posted here, then I stopped.
Dirty signal = smoking sub.
Clean signal = loud sub.
So the problem we're talking about here is human error; Cranking up that 100w amp's gains to the point of mass-clipping, because 100 clean watts isn't making enough noise on your 400wRMS sub.
Underpowering a sub is fine.
Hey Shawn - first time I saw you on here...I browse here every once in a while too. Are you going to Neil's show on the 3rd?
Anyway, I would listen to Shawn, he knows his ish...and here's my 2 cents on a couple of amps that'll give you 3K or more:
XXX6500D
T30001
XA3000D
Collosus
Good luck with your setup.
John
im going to post my two cents here...
clipped waves do not kill subs, clipped amps kills subs... a speaker is a simple device, you put alternating current through it, it moves back and forth. it doesent care what the shape of a wave is, it just does what it is told and nothing more. sure a square wave may go out, pause, go in, pause, go out, etc ,etc , etc... and during that pause it may allow the coil to heat slightly more than during a completely sinusoidal wave. however, consider this, the largest cooling factor for a voice coil comes from the back and forth motion of the coilitself. and a coilplaying a 60Hz wave moves back and forth 60 times a second no matter what the shape of the wave is.
when most people chalk a fried coil up to clipped waves, it is more accuratly said that a clipped amp did the damage. when amps go into clipping they do some pretty insane things, like producing waaaay more power than they do under normal operating conditions. more power leads tomore heat, more heat leads to blown coils...
in summation, waves do not killspeakers, heat does. and a square wave alone should not produce the extra heat neccesary to cause failure. but combine that with the extra power from a clipped amp...
boom boom room
boom boom room
Bolton,ON
hoss
ThxOne
    May 13, 2026
ThxOne
    May 13, 2026
