3 way component speakers
i'm going to replace the factory speakers.
i don't want to spend more than $600.
i've heard that it is better to buy a 3 way component system like the boston than buy the MB quart PCE-210 and the PCE-164 because the boston X-over is better...
I have a Soundstream SPL component speakers and i think they sound good...
Those are the top-of-the-line Bostons and mid-low end Quarts so I would hope that the Bostons have a better crossover. Any particular reason that you want a 3-way system? A 2-way system can sound just as good and sometimes better and takes less space and effort to install. For the same price as a mid level 3-way system, you can get the high-end 2-way system from a company such as CDT from the Zeb for example. Many of the really high-end companies don't make 3-way systems in their high end lines because with a good enough midrange/midbass, two speakers can cover the whole frequency range (minus the sub-bass) and fewer speakers, means fewer phasing and cancellation issues to deal with. The only real benefit of a 3 way system is when you are trying to match your high frequency set-up to a really powerful sub system and you need a dedicated midbass that will be making the tranistion between the subs and the mids. To make this work optimally, you will have to have a dedicated amp for the midbasses and cross everything actively. If you don't want to go that route, I would suggest getting a 6.5" two-way set. Your $600 will get you into a higher class of speaker in a 2-way than a 3-way and I think you will probably be happier.
I want a 3-way system because my car has 3-way speakers in front an a 2-way speakers in the back. Both are components. I'm going to replace the factory speakers so if i have the hole i'll use it to the speakers.
I'm going to use my soundstream SPL 60 to the back doors and i kneed to by speakers to the front. (3-way)
In quality are the Boston acoustics better than the CDT HD-642s ???
I've got a pair of boston rally series and they sound great. I think the sound is more smooth that the Soundstream...
yes those are top line compo, but have you looked into JBL's compo line, all have JBL equipment have been wonderful. but for the doe I would go with the CDT's or FOCAL's.
I second that...CDT or Focal...if I didn't spend so much $$$ on my JL's a while back I would go with one of the two.
e_coli
e_coli
Porto
urwhatueati8god
