3 SD-3 12 vs 2 SA 10s ported
KiaSoul10
Good day I would like to know which setup would be louder and have great sq kind of equally  3 SD3 12s or 2 SA 10s ported? I know one setup is sealed and one is ported but I would like to know hear some opinions. I'll be running a Orion xtr 2500.1d.
Ok if there tune to perfect spec. (3.0cu.ft for the 3 sd3 and the 2 sa10s tune to 2.0cu.ft 35hz)Which one would come out on top?
The SD-3 is an underhung design, it should have lower distortion than the SA's. (3) 12's vs (2) 10's you're giving up a lot of cone area...not sure if the additional gain of being ported will make up the difference in output. The SD-3 12's also have a lower FS...you could port them as well, but tune at a lower freq if you're looking for extended low-end.
I was considering the 12 sd3 because I really want to do 12s in my car but I know i can't fit 2 sa12s in the trunk so I said I'll think about going with the 3 12 sd3's being that they ain't to deep or 2 sa 10s. I am looking for a setup that goes low has sq and I want I it be loud. I was looking at the u12 also. What do you guys think about to u12? Playing with L40×d15×h13 in the trunk.
As long as the subs are close to each other and the signal to is not Inverted on any subs, cancellation is not a big issue with sealed enclosures...
23
Good explanation, thanks. I'll try installing that other amp soon. I have a stinger cap that shows my volts. It's reading 15v at max volume with...
17
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
KiaSoul10
KiaSoul10
KiaSoul10
    Apr 28, 2024
    Apr 28, 2024
