3 old school ads amp
radwilsons5803
Minnesota
1) PQ8
2) PQ8
3) P100
1) In great shape, few flaws here and there
2) Missing one mounting bracker, has a little rust, few nics
3) Has a few flaws, comes with all screws etc.
Great amps that work flawlessly
1) $55
2) $55
3) $55
Shipping and Miscellaneous Item Information: Included in price
For anyone considering these, there are cables available on ebay as well. They will work fine even though they are 6 channel cables. Also these amps are extremely clean and will produce as much volume as amps that are rated much higher in power than these.
I do not know if they are or not. The manual does not state that you can. You know Rick? ^^^^ . Or anyone for that matter haha
I know it s a FS thread and maybe I should route this post to another forum.
I am contemplating these amps...but...
Since I have a factory BMW HU, I would need a LOC, with these specific amp(s), correct?
Basically.....HU to LOC via OEM speaker cables...... LOC to "fancy" A/D/S/ DIN cable .... ??? And then the Fancy A/D/S/ DIN cable into the amp....
However, I'm currently running the factory HU to a cheap crutchfield amp without a LOC. I was informed by connecting my HU to the amps speaker level inputs I did not need to use a LOC.
Again, sorry for the questions. If anything...Courtesy bump!
Yeah, as long as your amp has speaker level inputs you do not need a LOC. The ADS amps do not have this so you will need some sort of LOC, or oem integration signal processor etc. So you are correct, thanks
Not all 3 have same issue. Was just giving an example of the issues Each one has its own issue Yes I did replace rca cables and swapped left and...
  • Locked
Clearing out storage. $75 + shipping. Located in Carlsbad, CA. Pick up OK. Shipping weight is probably around 13 pounds. Slightly to deep to...
radwilsons5803
radwilsons5803
Minnesota
radwilsons5803
