3 ohm speaker in a 4 ohm amp?
  • 4
Chistopher
None
Forgive me if this is one of those questions that has been asked 1000 times.
I picked up one of those fancy new smart amps from Kicker, the 200.4. It's rated for 4×50w @ 4 Ohms. The two rear speaker clusters are a pair of Boston Acoustics Pro60 SE, rated a 3 Ohms each. The two front speakers are rated at 4 Ohms each
From what I understand about running with lower than stable impedance speakers they will be louder, but cause the amp to heat up more. Given that I don't plan on running the unit louder than half volume for extended periods of time and that the amp is right near out an output of the car's AC, this shouldn't cause any problems right?
and another novice question while I'm here, if I'm running 50w to the mid and treble, 150w per to two 8" subs is enough to keep up right?
Should be just fine. If you need more power, just get another amp dedicated for subs only. Id recommend at least 100 rms overhead on tap. A little head room never hurts. But you should be fine. Try it out before you spend any more funds. I always say.. Run what you got
Back deck, over trunk. Certainly not air tight. I know it’s a dramatic difference in chest compression when the back seat is open to the trunk...
29
I don't think it's that easy to answer "for a complete beginner". amp and speakers ratings are those peak or RMS? Are these already installed...
Lowering the impedance will also lower the speakers motor control, or damping, in physics no free lunch exists. It’s all give and take.
185
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
162
Chistopher
Chistopher
None
audiobaun
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
