3 amps of off sub preout???
Alpine CDM-7871 Description
  • 45W x 4 MOSFET Amplifier
  • MaxTune Tuner
  • Regulated 1-Bit DAC
  • Detachable Face
  • Bass Width & Treble Center Adjustment
  • Swing Mechanism
  • BBE Processor
  • Dual-Color Display with Level Meter
  • CD Text
  • Versatile Link Ready
  • Wireless Remote Control Ready
  • 4 Volt Subwoofer PreOut
  • 3 PreOuts
Why don't you use the subs preouts for the Vipers and the rear or front preout for the Pioneer?
Seems to be the better, more easier way;)
FYI a strapped pair is much more unstable than a running them seperately...
Just run the RCA's to Viper A then use the pass throughs to go to Viper B, then use those pass throughs to go to the Pioneer...
We've ran 2 strapped pairs of X-fires off 1 set of pre-outs w/o problems...
Am I correct to assume that the 6W0 is going to be on the Pioneer amp for the up front bass? If so this creates a major issue, the 12's are going to have way more amplitude than the 6" is. The 6" can play as deep a bass frequency but it cannot do it with anywhere near the same amplitude. This means that to properly use this system do not use the 6W0 as a sub bass driver, use it as a midbass driver. You will need a crossover with bandpass abilities and run it off of the front preout to do this properly.
Any speaker can be a sub, a sub is determined by the range of frequencies it plays. If this little tiny driver is going to be played with sub frequencies at the same time and on the same preout as the larger ported 12's, it is basically going to be a useless effort as the 12's have waaaaaaaaaaaaaaaaaaaaaayyyyyyyyyyy more amplitude at all frequencies. A 6" can and will produce sub bass but in this application would be much happier as a low midbass driver playing from 100 - 250 hz depending on the midbass hump in the car.
Here is the proper way to run it.
Front preout to crossover with bandpass ability.
HP out to front ampl
BP out to Pioneer amp - 6W0
This will limit the range of frequencies it will play and will allow a much more useable range of frequencies at the same time.
bonesninja
bonesninja
Lima, Ohio
bonesninja
