3 Alpine Type-R 12s to an MTX Thunder81000D
it all depends on how you have it wired....each sub has dual 4 ohm VC's right?...if that is the case, you can wire the coils in a series and the speakers in paralell and you will get a 2.7 ohm load, which will pull enough to run each speaker to its RMS power handling...you said three right...yea that is it...there is a diagram for it here
http://www.sounddomain.com/member_pages/view_page.pl?page_id=184004&page=2
it is at the very very bottom to the left, the one with three subs....check that it should help
this is all possible if the amp is 1000 watts is RMS...if it is 1000 max at 2ohms then it is a different story
senor_wae
senor_wae
San Antonio, tx
Wonderbread
