3- 8W7's in a ported Box can it get loud?
davidtemple
Caraudio Guru
I'm designing a box for 3 8w7's in a ported box. Doing a SQ install but just wanted to be loud enough for MECA if needed.
[1] Can I use one port for all 3 subs ?
[2] What SPL can I expect in a SUV firing back at the hatch? ( SQ ) Install
[3] I want to use a JL HD750 on all three subs with the gains lowered, will this be ok?
Any Advice good or bad would be appreciated. //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Sundown SAZ-1500 would be good for all three...depending on the ohm load...or if you want to stick with JL, throw a 500/1 on EACH sub.
It would be a lot cheaper to use the Sundown Amp, Never use one are they good for SQ also? Reliable?
Incase you're thinking an 8" woofer will have better SQ than a larger woofer, you're mistaken.
Two 12W6v2's will sound better & get louder (given the same power) than the 3 8W7's. The 12W6v2's will also do fine on the HD750, but would be better off w/ a PDX 1000.1.
Two 12W6v2's in a 2.75 ft^3 sealed enclosure =//content.invisioncic.com/y282845/emoticons/drool.gif.b5e863e893038027711d4402f340dad0.gif
Incase you're thinking an 8" woofer will have better SQ than a larger woofer, you're mistaken.Two 12W6v2's will sound better & get louder (given the same power) than the 3 8W7's. The 12W6v2's will also do fine on the HD750, but would be better off w/ a PDX 1000.1.
Eh, sounds good except for the PDX amp..those don't have any balls to them at all.
Go with a Sundown SAE-1200D if you decide to run two W6's...
Just don't know about these Sundown stuff.... need to ask around, I'm looking to get 140db with these 3 vented, if not I'll go with 10's or maybe 2-12's, I got a PM saying to go with FI Q's.
Any opinions?
A pair of American Bass Hawk 15s will slamm home as well. Just put in a pair in a good friends 02 T.Car in 7.0@31htz on a Cresendo Skyway 3k...
29
you may like them facing forward rather than Rear faced. Its all about how you like and enjoy by your ear/listening not others. try Both...
977
I scrolled thru there trying to find TS specs and must have missed them or they weren't displaying. Anyway, looks like 2cuft tuned to ~35hz was a...
davidtemple
Caraudio Guru
davidtemple
Louisville, KY
JayRich
    May 18, 2024
    May 18, 2024
