bhsdriller
fvck birch....I don't like how it machines compared to mdf, don't care about the weight saving either since I drive a truck
i do think the birch-ply is a superior product, just in ease of use and weight. however, i have never had an issue using MDF, and certainly never had it delaminate because ive never had a piece of mdf thats been laminated LOL. mdf is manufactured using fibers, wax, resin and high pressures and temps. no laminate involvedBut wouldn't you agree that it's a superior material as far as durability and longevity? I have had sheets of mdf de laminate on the way back to the shop!
I would think there would be a certain cut-off point where the box is proofed, that's interesting though. I was looking at some of those ugly probox enclosures yesterday with one of my girls, it's supposedly ''armor coated", but at this point I'm not sure with what. Hard like metal on the outside, but the box is made out of MDF. The ports are tuned too high for my taste (40-45hz). ProBox Custom UTV tops and Vehicle-Specific Subwoofers and EnclosuresI'm building a sealed box with double walled mdf so about 1.5 inch thick. I'll let you know how it turns out, I just wanted the box super ridget.
By de laminated I mean the 3/4 sheet separated into two sheets 3/8 thick! It was a raw sheet of material.i do think the birch-ply is a superior product, just in ease of use and weight. however, i have never had an issue using MDF, and certainly never had it delaminate because ive never had a piece of mdf thats been laminated LOL. mdf is manufactured using fibers, wax, resin and high pressures and temps. no laminate involved
armor coat spray on bedliner it's all the same and you can do it yourself cheap!I would think there would be a certain cut-off point where the box is proofed, that's interesting though. I was looking at some of those ugly probox enclosures yesterday with one of my girls, it's supposedly ''armor coated", but at this point I'm not sure with what. Hard like metal on the outside, but the box is made out of MDF. The ports are tuned too high for my taste (40-45hz). ProBox Custom UTV tops and Vehicle-Specific Subwoofers and Enclosures
Could someone answer #8 for me when they get a moment, thank you.
J
as someone else said, in large numbers of subs series/parallel wired in groups, I would Isolate the groups, like 8 12's in 2 groups of 4 in 2 separate chambers, but that is a personal preference depending on amp and VC configuration...in the average 2 sub set up, it depends on the amplifier(s). for 2 subs on 2 separate amplifier channels, I will do individual chambers. Just because you have two channels and the possibility of one sub being slightly out of phase with the other. For a monoblock amplifier set up, i combine the airspace.While I'm at it, may I ask a question about the separation of subwoofers within enclosures. I see some boxes without separation(between subwoofers). Can this be bad, If so, how so?
you know ridget like I waz gridin up on dis bich in da club and my d!k gotz allll "ridget" and *****!whats a "ridget"?
That 1+ inch front baffle on that box is kind of s.e.x.y.__Did you make that, do you make boxes? I need one made soon.armor coat spray on bedliner it's all the same and you can do it yourself cheap!![]()
This is an excellent point... I have no idea if the theory on slot ports possibly causing a slight turbulence vs flared ports hold water though. Visually, I can imagine how it could, but then I also think a more curved design inside and out of the box would also be more conducive to the way sound travels asOne advantage of a flared tube port is the ability to exchange it and have different lengths for different tunings (Daily/Comp) if the box is designed this way. This is one main advantage over a permanent Slot Port. Personally, I prefer Slot ports.
The only thing I'd be hesitant about with dual subwoofer enclosures without individual chambers is that if one subwoofer blows the other is likely to blowRe individual chambers vs dual sub setups without individual chambers. I will do individual chambers. Just because you have two channels and the possibility of one sub being slightly out of phase with the other. For a monoblock amplifier set up, i combine the airspace.
If one sub blows or just stops playing, there's a good chance the other will suffer mechanical damage due to the sudden strain of being in a box twice the proper size. Another point I think could be an issue with enclosures without individual chambers is that I don't see bass rhythms sent in stereo to the rightuhhhmmmm....whut?
