3/4 Mdf
And if i already had the parts cut? cant recalculate the volume now.... but it is a large box so It more in likely will flex..... should I just add a 2" brace in the middle to hold things down?
Brace it like mad;
Flex is bad.
I mean, if you have a piece of stock thats 2x2x16 ... I just used 16 as the number for your height, I don't really know what the exact number is ... anyway, 2x2x16 is only .037ft^3 ... you can add 3 of those and you'll only end up subtracting .111ft^3 brace displacement - hopefully your box is a little bigger than spec //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
- Steve
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
ssj2xxgotenxx
The Chan Man
ssj2xxgotenxx
Bay Area
ss3079
