clearly. for aeros its better if you run one bigger port instead of more smaller ports. just do a 6That equals around 21 square inches correct? You think that would be enough (i know on the low side) for 3 cubes? I never really deal too much with aero's..
Thanks
you can't put the port on a different wall? just get a 90* elbow, problem solved. you want atleast the radius of the port worth of distance from the port in all directions.Nah. Customer doesn't want a square port. Is there a certain amount of space that should be between the end of port to back baffle?
