3 12's need and amp
  • 4
3 four ohm woofers will put a load of 1.33ohms on the amp(theres a formula), A JBL 1200 is rated to handle a minimum of 1ohm, your in good shape with this set up go for it.
956
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
* The fuse at the start of the cable needs to be equal to or greater than the fuse/load at the end of the run. * The cable needs to be capable of...
Thank you for your reply. What if I wire in series for 8 ohm load ? Sorry for my newbie questions, but wouldn't it have better sound quality...
liwaj79
liwaj79
fremont ohio
audiolife
