2xFI BL fully loaded 5000rms ?????
Audio Master
well as the title states i have 2 FI BLs fully loade ofcouse in the biggest box i could get into the car about 5sh cubes and tuned to around 35-40hz
I have one of our own custom D class amps and its a 5000rms i need to use this amp as i will upgrade the subs when our new ones arrive from the US (they are 2500wrms each will be using 2 x 12")
will they work ???
the FIs with the 5000wrms amp (and its a real 5000wrms) or will they fry
as i dont want to blow the FIs if I run the gains real low will it work
ohhh and they are D2 vcs aswell
any thoughts on this dilemia:confused:
Of course it'll work, set your gains right and just keep an eye on them, or they'll go poof //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
first is this for daily or burps? itll handle it for burps for sure. and daily i wouldnt put more then 2000 per sub
thanks peeps well it is for daily till my new subs arrive but i do a fair bit of comp stuff but on music only i
its just i need the 5k amp for the new ones and i dont want to run 2x2000wrms as that is the other option
i figured 1 x 5000wrms and keep the gains REAL low watch that i keep the subsonic just right and loverly
but if i have to ill put in 2 x 2000wrms and run 1 sub per amp they should get around 1900ish per sub i dont know if the 2000wrms is rated right and havent tested it yet
but the 5000 is definatly 5000 and will do 7500wrms but thats at 18v and im running at a healthy 14,4 and 12.6 at full burps went as low as 11,8 but thats when the last subs went poof
hence the rebuild
the subs are duel 2 do you reckon wire them for 2ohm load or risk a .5 ohm
or go 1ohm with 2x2000amps
thanks for the help people:veryhapp://content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif
https://www.amazon.com/gp/product/B0016G4EXQ/?tag=caraudiocom-20 https://www.amazon.com/gp/product/B07BMT699G/?tag=caraudiocom-20 Im not a fan of...
Audio Master
Audio Master
Perth, Western Australia, Australia
Audio Master
