2x MOFO 15's
they get loud but dont sound good plain and simple and homie you would need an amp that does max power at .5 ohm or 2 ohm they both won't wire to 1 ohm just like that pa amp its all a good deal but at 2 ohm its rated at 1800rms and its a pa amp so it wont do close to that prob. around 1500rms.
if you port them itll sound liek a SPL fart....lots of dB's...lots of fart bass......
with enough power and the right ported box though you can get some sick results out of those subs, just check your cone temp every so often after long playing so you know if you're close to blowing it or not,.....
the box i built is 32 x 30 x 18 ported at 35 hz 12 cu ft^3 TOTAL
something like 4.5 cu ft^3 NET /per sub
If you just want to slump that should work fine. Those subs aren't bad, they're definitely loud and handle their power, they are just difficult to make sound good.
Decipha
www.EFI Dyno Tuning.com
Decipha
New Orleans, LA
luvofmusic
Mike Mccabe
