2x 15's ext cab s10
That would be about 7.78cu/ft using 3/4 mdf. Kinda tight for 2-15's IMO but it'll work. You then subtract the subs displacement and Voila. lets say your subs displace .5cu/ft each that would take it down to 6.78cu/ft. you also have to subtract any port volume as well. If sealed then fine but sealed is for SQ mainly. I use Aeroports they add cost $ wise, but I've always had decnt results. here's a link for you to play around with
Subwoofer Enclosure Calculators, Fraction to Decimal, Parallel, Series, Port Length and Volume Calculators
Enjoy!
And you have to take out port displacement(and bracing) as well in order to calculate tuning...the subs won't displace that much air space either, ~.2ft^3 each depending on the sub.
200 for each sub? if so look into the presale sa-15's. they don't need alot of airspace to run a pair. your s-10 is similair to my frontier on space. that is why i went with them.
I just found out I might have a bit of a higher budget today, around $400-ish. How are the IA Death Penalty or Death Row's?
You must have a newer S10, huh? Because I have a '92 and have way more room than that. I didnt' realize there was such a difference in body styles.
It's a '95. I could get more room If I'd do a wall, but still want to have use of the rear view. Granted that would solve my problem of my sliding rear glass being a trash can lid! And the 16" depth I am sort of stuck with since I am on the taller side and moving it up more then that I would be a bit crammed.
My last box was a 40x18x16 (I think) and the seat was up more then it would normally be, but tolerable.
Tragic00
I am Omega
Tragic00
Ohio
Tragic00
vegang
vegang
