24's or 26's
what the difference in the 295/305 in tire size is that height or what, nvm its the width of the tire haha
yea i could do the 295/35/26 its 34.12 diameter and has 4.06" for sidewall and only 11.61" wide compared to 12"
or if i have rubbing problems which i dont think i will with 295's compared to 305's i could go with the 295/30/26 its 32.96" diameter but only 3.48" sidewall want at least a 4" sidewall
will those 295's work on that rim the rim is 10" wide
thats what i been using above haha thanks though.
and i cant even find a 295/35/26 tire i am looking right now online
Looking to go with 24's at least possibly 26's if i can get away with no rubbing without adding a leveling kit since its only 1" difference from the front and the back height difference, and the smallest leveling kit i have found is 2" and dont want it to sit up higher in the front than the back.
i measured from the ground to the fender i have 33" in the front and 34" in the back.
Then i measured from front to back in the wheel wells as in horiziontal in the front and back i got 36" so would i rub with 26's
What do you think
You can do a set of 26's w/ 305/30/26
26s measure 32.4 with 305/30/26 tires.
If you go with 26s get a +15 or +20 offset with 26s.
You have enough room on that type of truck for 26s w/o rubbing or scrapping
I will get a pic of both my trucks with 26s
You can do a set of 26's w/ 305/30/2626s measure 32.4 with 305/30/26 tires.
ok well i was hoping to get a 305/25/26 tire for extra sidewall to have at least 4" for sidewall so i dont bend my rims.
or i could do the 295/35/26 right, i was told to get tire that will fit inside the wheel well and not outside the wheel well so on bumps and such it doesnt hit the fender and screw the truck up instead it will raise into the fender well
theking
theking
us
theking
    Jun 1, 2024
    May 31, 2024
