220a Alt... STILL getting voltage drops! WTF?!
OoMesKoO
Me > Newbs. :fyi:
I just bought a Iraggi 220a amputator series alt. At full tilt, I still see voltage drops down to around 10-11v. Now my question is, is it because I am only running 1 stock battery? Would adding a second solve my problems? I figured with 175a at idle speed, I would more than cover what my stock battery wasnt supplying. Maybe im wrong?
have someone rev it to 2k rpm while you use your DMM to check ur drops.
although your running 3200watts, 10-11 still seems too low for an alty that does 175 at idle
Should've got a bigger alt....I only have about 2000watts and I'm still seeing 14.3volts at my amps with them all the way up...I have done the big 3 and only have a Red Top under the hood with the alt. in my sig. (which is also 175amp @ idle)
OoMesKoO
Me > Newbs. :fyi:
OoMesKoO
Rhode Island
MikeyB
