2014 voltswagon Jetta se alternator help
I️ fiberglassed my front doors for 3 components and 2 4inch speakers all kicker ks want to do the same with the rear then I️ have 4 6x9 on the rear deck and I want to run 4 2000 rms subwoofers so I️ need a lot of power
Oh this should get better. I wouldn't worry about the rear speakers at all, since most of the sound comes from the front. Esp if you plan to run subs, gonna need to port thru the rear deck...unless you have a ski hole.
6th gen Jettas have a ski pass and 40/60 split folding rear seats.
Mechman makes a HO alt for the 2.5L, not sure if they make one for the 1.8
Ohio Generator is another good company, you'll have to contact them directly.
I'd really suggest adding a Burger Motorsports JB1, they add a nice little bump in power.
Essesive amperage can make one that is 200 amps at engine idle and 250 at about 2000 rpms which is a good start now I️ need to see if I can fit 2
And I️ do plan on building a box that air ports thru the top of the rear deck
Also how many watts/rms does 1 zero gage run handle I’m not sure how many I️ need to run
Essesive amperage can make one that is 200 amps at engine idle and 250 at about 2000 rpms which is a good start now I️ need to see if I can fit 2 And I️ do plan on building a box that air ports thru the top of the rear deck
1/0 OFC will handle roughly 300a of current
1/0 CCA will handle roughly 250a of current
PICKELITESOUNDZ
PICKELITESOUNDZ
Chicago
THATpurpleKUSH
